ONTAP commands
system services web ontapi modify
Unsuspend ONTAPI after auto suspend
This command allows users to un-suspend ONTAPI after it has been automatically suspended
[-suspended {true|false}] - ONTAPI suspended status
Defines whether ONTAPI is currently suspended or not.
  1. Example status of ONTAPI being suspended:
cluster1::> system services web ontapi show
ONTAPI Suspended
true
  1. The following example un-suspend ONTAPI:
cluster1::> system services web ontapi modify -suspended false
  1. Attempting to manually set the suspend status to true will result in an error:
cluster1::> system services web ontapi modify -suspended true
Error: command failed: ONTAPI cannot be manually suspended. Use the "vserver
       services web" CLI command to disable the ONTAPI service.
