      volume encryption secure-purge abort
Abort secure deletion of trash in existing volume
The volume encryption secure-purge abort command aborts the secure purge operation on a volume.
- -vserver <vserver name>- Vserver (privilege: advanced)
This parameter specifies the Vserver on which the volume is located.
- -volume <volume name>- Volume (privilege: advanced)
This parameter specifies the name of the volume being encrypted.
 PDFs
PDFs
