network options cluster-health-notifications show
Display cluster health notification options
The network options cluster-health-notifications show command displays whether the node's cluster health notifications are enabled.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
This parameter specifies the node for which the cluster health notification status will be displayed.
[-enabled {true|false}]- Cluster Health Notifications Enabled-
Selects the entries that match this parameter value.
The following example displays the cluster health notification status for a node:
cluster1::> network options cluster-health-notifications show -node node1
Node: node1
Cluster Health Notifications Enabled: true
