ONTAP commands
network options cluster-health-notifications show
Display cluster health notification options
The network options cluster-health-notifications show command displays whether the node's cluster health notifications are enabled.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
This parameter specifies the node for which the cluster health notification status will be displayed.
[-enabled {true|false}] - Cluster Health Notifications Enabled
Selects the entries that match this parameter value.
The following example displays the cluster health notification status for a node:
cluster1::> network options cluster-health-notifications show -node node1
                                 Node: node1
 Cluster Health Notifications Enabled: true
