network options cluster-health-notifications show
Display cluster health notification options
The network options cluster-health-notifications show
command displays whether the node's cluster health notifications are enabled.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
This parameter specifies the node for which the cluster health notification status will be displayed.
[-enabled {true|false}]
- Cluster Health Notifications Enabled-
Selects the entries that match this parameter value.
The following example displays the cluster health notification status for a node:
cluster1::> network options cluster-health-notifications show -node node1 Node: node1 Cluster Health Notifications Enabled: true
