ONTAP commands
storage aggregate show-status
Display aggregate configuration
The storage aggregate show-status command displays the RAID layout and disk configuration of aggregates. The command output depends on the parameter or parameters specified with the command. If no parameters are specified, the command displays information about all aggregates in the cluster.
Note This command does not use pagination. You can reduce the output by filtering with the parameters below.
{ [-fields <fieldname>,…​]
| [-instance ] }
This parameter currently has no effect.
[-aggregate <text>] - Aggregate Name
Selects the aggregates that match this parameter value.
[-node <nodename>] - Node
[-aggregate-uuid <UUID>] - Aggregate UUID
Display the RAID layout of a Flash Pool aggregate.
cluster1::> storage aggregate show-status -aggregate nodeB_flashpool_1
Owner Node: node-b
 Aggregate: nodeB_flashpool_1 (online, raid_dp, hybrid) (block checksums)
  Plex: /nodeB_flashpool_1/plex0 (online, normal, active, pool0)
   RAID Group /nodeB_flashpool_1/plex0/rg0 (normal, block checksums)
                                                              Usable Physical
     Position Disk                        Pool Type     RPM     Size     Size Status
     dparity  1.1.7                        0   BSAS    7200  827.7GB  828.0GB (normal)
     parity   1.1.8                        0   BSAS    7200  827.7GB  828.0GB (normal)
     data     1.1.10                       0   BSAS    7200  827.7GB  828.0GB (normal)
     data     1.1.11                       0   BSAS    7200  827.7GB  828.0GB (normal)
     data     1.1.12                       0   BSAS    7200  827.7GB  828.0GB (normal)
RAID Group /nodeB_flashpool_1/plex0/rg1 (normal, block checksums) (Storage Pool: SP2)
                                                              Usable Physical
     shared   1.0.22                       0   SSD        -  186.2GB  745.2GB (normal)
     shared   1.0.20                       0   SSD        -  186.2GB  745.2GB (normal)
     shared   1.0.18                       0   SSD        -  186.2GB  745.2GB (normal)
     shared   1.0.16                       0   SSD        -  186.2GB  745.2GB (normal)
