security login duo group modify
Modify a Duo Group Configuration
The security login duo group modify command modifies the Duo groups.
-vserver <vserver name>- Vserver-
This parameter optionally specifies the Vserver of the group for which the 'exclude-users' or 'comment' is being modified.
-group-name <text>- Group Name-
This parameter specifies the name of the group for which the 'exclude-users' or 'comment' is being modified.
[-excluded-users <text>,…]- List of Excluded Users-
This parameter specifies the list of users to be excluded from Duo authentication.
[-comment <text>]- Comment-
This parameter specifies the comments.
The following command modifies the excluded users for the group test who is part of Vserver vs1.
cluster1::> security login duo group modify -vserver vs1 -group-name test -exclude-users tsmith, jane
