The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
system services ndmp node-scope-mode off
PDF of this doc site
Creating your file...
Your file is ready
(DEPRECATED)-Disable NDMP node-scope-mode
This node-scoped NDMP command is deprecated. Node-scoped NDMP functionality may be removed in a future release of Data ONTAP. Use the Vserver-aware "`vserver services ndmp` " command. |
This command puts NDMP server in Vserver-aware mode. The Vserver-aware commands are available under vserver services ndmp
The following example shows how to disable the node-scope-mode of NDMP server.
cluster1::> system services ndmp node-scope-mode off NDMP node-scope-mode is disabled.
