volume flexcache create
Create a new cache relationship
The `volume flexcache create` command is used to create a FlexCache volume. It also creates the relationship between the FlexCache volume and the specified origin volume.
If the vserver and origin-vserver are different, the Vservers must be in a peer relationship.
-vserver <Vserver Name>- Vserver Name-
This specifies the Vserver on which the FlexCache volume is to be created.
-volume <volume name>- Cache Volume Name-
This specifies the name of the FlexCache volume that is to be created.
[-aggr-list <aggregate name>,…]- List of Aggregates for FlexGroup Constituents -
Specifies an array of names of aggregates to be used for creating the FlexCache volume. Each entry in the list will create a constituent on the specified aggregate. The root constituent will always be placed on the first aggregate in the list, unless
optimize-aggr-listis specified astrue. An aggregate may be specified multiple times to have multiple constituents created on it. This parameter only applies to FlexGroups. [-aggr-list-multiplier <integer>]- Aggregate List Repeat Count-
Specifies the number of times to iterate over the aggregates listed with the
-aggr-listparameter when creating a FlexGroup. The aggregate list will be repeated the specified number of times. Example:
-aggr-list aggr1,aggr2 -aggr-list-multiplier 2
will cause four constituents to be created in the order aggr1 , aggr2 , aggr1 , aggr2 .
The default value is 4.
[-optimize-aggr-list {true|false}]- Have the System Optimize the Order of the Aggregate List-
Specifies whether to create the constituents of the FlexCache volume on the aggegates specified in the
aggr-listin the order they are specified, or whether the system should optimize the ordering of the aggregates. If this value istrue, the system will optimize the ordering of the aggregates specified in theaggr-list. If this value isfalsethe order of theaggr-listwill be unchanged. The default value isfalse. This parameter only applies to FlexGroups. - |
[-auto-provision-as <FlexGroup>]- Automatically Provision as Volume of Type -
Use this parameter to automatically select existing aggregates for provisioning the FlexCache volume.
[-use-tiered-aggregate {true|false}]- Automatically Provision FlexGroup on FabricPool }-
This parameter specifies whether or not FabricPool-enabled aggregates are selected when provisioning a FlexCache volume using the
auto-provision-asparameter. Only FabricPool-enabled aggregates are used if this parameter is set to true and only non-FabricPool-enabled aggregates are used if this parameter is set to false. The default value isfalse. Tiering-policy is alwaysnonefor FlexCache.This parameter only applies to FlexCaches created using the
-auto-provision-asparameter. [-size {<integer>[KB|MB|GB|TB|PB]}]- Volume Size-
This optionally specifies the size of the FlexCache volume. The size is specified as a number followed by a unit designation: k (kilobytes), m (megabytes), g (gigabytes), or t (terabytes). If the unit designation is not specified, bytes are used as the unit, and the specified number is rounded up to the nearest 4 KB. If the size parameter in not specified, it defaults to 10% of the origin volume size.
[-origin-vserver <vserver name>]- Origin Vserver Name-
This specifies the name of the Vserver where the origin volume is located.
-origin-volume <volume name>- Origin Volume Name-
This specifies the name of the origin volume.
[-junction-path <junction path>]- Cache Junction Path-
This optionally specifies the FlexCache volume's junction path. The junction path name is case insensitive and must be unique within a Vserver's namespace.
[-foreground {true|false}]- Foreground Process-
This specifies whether the operation runs in the foreground. The default setting is
true(the operation runs in the foreground). When set to true, the command will not return until the operation completes. [-s, -space-guarantee {none|volume}]- Space Guarantee Style-
This optionally specifies the space guarantee style for the volume. A value of
volumereserves space on the aggregates for the entire volume. A value ofnonereserves no space on the aggregates, meaning that writes can fail if an aggregate runs out of space. The default setting for the FlexCache volumes isnone. [-preserve-msid {true|false}]- Preserve Origin MSID on the Cache (privilege: advanced)-
Create the cache with the same MSID as the origin. Set this parameter to
trueto create FlexCache DR. The default setting for the FlexCache volumes isfalseto avoid a situation where a FlexCache create operation using-preserve-msidfails on a Vserver because of collision with a previously used MSID. [-is-global-file-locking-enabled {true|false}]- Global File Locking Mode Enabled/Disabled-
This parameter specifies the global file locking mode for the volume. The default value of global file locking mode is
false. [-is-relative-size-enabled {true|false}]- Is Relative Sizing Enabled/Disabled (privilege: advanced)-
This parameter specifies whether the relative sizing is enabled for the FlexCache volume. Relative sizing is introduced as a part of follow the origin feature. When relative sizing is enabled, it will block any modifications done manually in the absolute size of the FlexCache. The size of FlexCache will be calculated and entered automatically based on the size of the origin. The default value for create is
false. [-relative-size-percentage <integer>]- Relative FlexCache Size Percentage (privilege: advanced)-
This parameter specifies the percent size FlexCache should have relative to the total size of the origin. The default value for create is 10%.
[-override-encryption {true|false}]- Override FlexCache Volume Encryption-
Use this parameter to create a plaintext FlexCache volume of an encrypted origin volume. The default value is
false.This parameter cannot be modified after the FlexCache volume is created. [-is-atime-scrub-enabled {true|false}]- Is atime-Based Scrubbing Enabled/Disabled (privilege: advanced)-
This parameter specifies whether automatic scrubbing of inactive files based on atime is enabled. When enabled, inactive files are automatically scrubbed based on specified atime duration. The scrubbing operation will only occur if
-atime-updateis enabled on the FlexCache volume. The default value for the atime scrubber isfalse. [-atime-scrub-period <integer>]- Days After Which An Inactive File Is Scrubbed (privilege: advanced)-
This parameter specifies the number of days for inactivity on a file after which the file will be scrubbed out. The default value is 30 days.
[-is-cifs-change-notify-enabled {true|false}]- Is CIFS CHANGE_NOTIFY Enabled/Disabled (privilege: advanced)-
This parameter specifies whether the FlexCache volume sends change notifications to CIFS clients. The default value is
false.
The following example triggers FlexCache volume create:
cluster1::> flexcache create -vserver vs34 -volume fc1 -aggr-list aggr34,aggr43 -origin-volume origin1 -size 400m (volume flexcache create) [Job 894] Job succeeded: Successful
cluster1::> flexcache create -vserver vs34 -volume fc3 -auto-provision-as flexgroup -origin-volume origin1 -size 400m (volume flexcache create) [Job 898] Job succeeded: Successful
cluster1::> flexcache create -vserver vs34 -volume fc4 -aggr-list aggr34,aggr43 -origin-volume origin1 -size 400m -junction-path /fc4 (volume flexcache create) [Job 903] Job succeeded: Successful
