event filter test
Test an event filter
The event filter test command is used to test an event filter. When specified with a message name, the command displays whether the message name is included or excluded from the filter. When specified without a message name, the command displays the number of events from the catalog that match the filter. For more information, see the event filter create command.
-filter-name <text>- Filter Name-
Use this mandatory parameter to specify the name of the event filter to test.
[-message-name <Message Name>]- Message Name-
Use this optional parameter to specify the message name of the event to test against the filter.
The following example tests an event filter named err-wafl-no-scan-but-clone:
cluster1::> event filter show
Filter Rule Rule SNMP Trap
Name Posn Type Message Name Severity Type Parameters
default-trap-events
1 include * EMERGENCY, ALERT
2 include * * Standard, Built-in
3 exclude * * * *=*
1 include wafl.scan.clone.*
2 exclude wafl.scan.* * * *=*
3 include wafl.* EMERGENCY, ALERT, ERROR
4 exclude * * * *=*
important-events
2 include callhome.* ERROR * *=*
3 exclude * * * *=*
no-info-debug-events
1 include * EMERGENCY, ALERT, ERROR, NOTICE
2 exclude * * * *=*
12 entries were displayed.
cluster1::> event filter test -filter-name err-wafl-no-scan-but-clone
271 events will be included in the given filter.
cluster1::> event filter test -filter-name err-wafl-no-scan-but-clone -message-name wafl.scan.clone.split.cantLock
The message-name "wafl.scan.clone.split.cantLock" is included in the given filter.
cluster1::> event filter test -filter-name err-wafl-no-scan-but-clone -message-name wafl.scan.layout.cantWrite
The message-name "wafl.scan.layout.cantWrite" is excluded from the given filter.
