event filter test
PDF of this doc site
Creating your file...
Your file is ready
Test an event filter
The event filter test
command is used to test an event filter. When specified with a message name, the command displays whether the message name is included or excluded from the filter. When specified without a message name, the command displays the number of events from the catalog that match the filter. For more information, see the event filter create command.
-filter-name <text>
- Filter Name-
Use this mandatory parameter to specify the name of the event filter to test.
[-message-name <Message Name>]
- Message Name-
Use this optional parameter to specify the message name of the event to test against the filter.
The following example tests an event filter named err-wafl-no-scan-but-clone:
cluster1::> event filter show Filter Name Rule Rule Message Name SNMP Trap Type Severity Position Type ----------- -------- --------- ---------------------- --------------- -------- default-trap-events 1 include * * EMERGENCY, ALERT 2 include * Standard, Built-in * 3 exclude * * * err-wafl-no-scan-but-clone 1 include wafl.scan.clone.* * * 2 exclude wafl.scan.* * * 3 include wafl.* * EMERGENCY, ALERT, ERROR 4 exclude * * * important-events 1 include * * EMERGENCY, ALERT 2 include callhome.* * ERROR 3 exclude * * * no-info-debug-events 1 include * * EMERGENCY, ALERT, ERROR, NOTICE Filter Name Rule Rule Message Name SNMP Trap Type Severity Position Type ----------- -------- --------- ---------------------- --------------- -------- no-info-debug-events 2 exclude * * * 12 entries were displayed. cluster1::> event filter test -filter-name err-wafl-no-scan-but-clone 271 events will be included in the given filter. cluster1::> event filter test -filter-name err-wafl-no-scan-but-clone -message-name wafl.scan.clone.split.cantLock The message-name "wafl.scan.clone.split.cantLock" is included in the given filter. cluster1::> event filter test -filter-name err-wafl-no-scan-but-clone -message-name wafl.scan.layout.cantWrite The message-name "wafl.scan.layout.cantWrite" is excluded from the given filter.
