storage failover check-takeover
Display status for all takeover options
The `storage failover check-takeover ` command displays information about whether takeover is possible based on verification checks triggered by the `-check-only ` parameter used with the storage failover takeover command.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node {<nodename>|local}]- Node
Name of node command is run from
- [-operation {takeover|giveback}]- Operation
Failover Operation Type
- [-option <takeover option>]- Takeover Option
Takeover Option
- [-operation-status {true|false}]- Operation Status
Status of whether defined operation would succeed or not
- [-reason <text>,…]- Reasons for Failure
Reason for pre-takeover failure
The following is an example of the storage failover check-takeover command:
cluster1::*> storage failover check-takeover Node Operation Option Operation-Status Reasons for Failure -------------- ----------- ----------- ---------------- ------------------- Node 1 Takeover normal false Takeover request failed due to giveback in progress
 PDFs
PDFs
