ONTAP commands
storage failover check-takeover
Display status for all takeover options
The `storage failover check-takeover ` command displays information about whether takeover is possible based on verification checks triggered by the `-check-only ` parameter used with the storage failover takeover command.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Name of node command is run from
[-operation {takeover|giveback}] - Operation
Failover Operation Type
[-option <takeover option>] - Takeover Option
Takeover Option
[-operation-status {true|false}] - Operation Status
Status of whether defined operation would succeed or not
[-reason <text>,…​] - Reasons for Failure
Reason for pre-takeover failure
The following is an example of the storage failover check-takeover command:
cluster1::*> storage failover check-takeover
Node           Operation   Option      Operation-Status Reasons for Failure
Node 1         Takeover    normal      false            Takeover request failed due to giveback in progress
