system license status show
(DEPRECATED)-Display license status
|  | This command is deprecated and may be removed in a future release of Data ONTAP. Use the "system license show-status " command. |
This command displays the list of licensable packages in the system and their current licensing status.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-package <Licensable Package>]- Package Name
If you use this parameter, the command displays information only about the specified package.
- [-method {none|license|site|demo|subscr|capacity|enabled}]- Licensed Method
If you use this parameter, the command displays information only about the packages with the specified licensed method.
- [-expiration <MM/DD/YYYY HH:MM:SS>]- Expiration Date
If you use this parameter, the command displays information only about the licenses that have the expiration date you specify.
- [-description <text>]- Description
If you use this parameter, the command displays information only about the licenses that match the description you specify.
- [-status-details <text>]- Additional Information About Status
This option displays additional information regarding the cluster-level license status for license methods.
The following example displays the license status of the cluster:
cluster1::> system license status show
Package            Licensed Method  Expiration            Status Details
Base               site             -                     -
NFS                site             -                     -
CIFS               demo             12/7/2015 00:00:00    Demo expires on given date
iSCSI              none             -                     -
FCP                none             -                     -
SnapRestore        none             -                     -
SnapMirror         none             -                     -
FlexClone          none             -                     -
SnapVault          none             -                     -
SnapLock           none             -                     -
SnapManagerSuite   none             -                     -
SnapProtectApps    none             -                     -
V_StorageAttach    none             -                     -
SnapLock_Enterprise
                   none             -                     -
Insight_Balance    none             -                     -
OCShift            none             -                     -
Cloud              subscr           12/15/2015 00:00:00   Subscription expires on given date
17 entries were displayed.
 PDFs
PDFs
