system license status show
PDF of this doc site
Creating your file...
(DEPRECATED)-Display license status
This command is deprecated and may be removed in a future release of Data ONTAP. Use the "system license show-status " command. |
This command displays the list of licensable packages in the system and their current licensing status.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-package <Licensable Package>]
- Package Name-
If you use this parameter, the command displays information only about the specified package.
[-method {none|license|site|demo|subscr|capacity|enabled}]
- Licensed Method-
If you use this parameter, the command displays information only about the packages with the specified licensed method.
[-expiration <MM/DD/YYYY HH:MM:SS>]
- Expiration Date-
If you use this parameter, the command displays information only about the licenses that have the expiration date you specify.
[-description <text>]
- Description-
If you use this parameter, the command displays information only about the licenses that match the description you specify.
[-status-details <text>]
- Additional Information About Status-
This option displays additional information regarding the cluster-level license status for license methods.
The following example displays the license status of the cluster:
cluster1::> system license status show Package Licensed Method Expiration Status Details ----------------- --------------- -------------------- ---------------------- Base site - - NFS site - - CIFS demo 12/7/2015 00:00:00 Demo expires on given date iSCSI none - - FCP none - - SnapRestore none - - SnapMirror none - - FlexClone none - - SnapVault none - - SnapLock none - - SnapManagerSuite none - - SnapProtectApps none - - V_StorageAttach none - - SnapLock_Enterprise none - - Insight_Balance none - - OCShift none - - Cloud subscr 12/15/2015 00:00:00 Subscription expires on given date 17 entries were displayed.
