system license status show
(DEPRECATED)-Display license status
This command is deprecated and may be removed in a future release of ONTAP. Use the "system license show-status " command. |
This command displays the list of licensable packages in the system and their current licensing status.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-package <Licensable Package>]- Package Name-
If you use this parameter, the command displays information only about the specified package.
[-method {none|license|site|demo|subscr|capacity|enabled}]- Licensed Method-
If you use this parameter, the command displays information only about the packages with the specified licensed method.
[-expiration <MM/DD/YYYY HH:MM:SS>]- Expiration Date-
If you use this parameter, the command displays information only about the licenses that have the expiration date you specify.
[-description <text>]- Description-
If you use this parameter, the command displays information only about the licenses that match the description you specify.
[-status-details <text>]- Additional Information About Status-
This option displays additional information regarding the cluster-level license status for license methods.
The following example displays the license status of the cluster:
cluster1::> system license status show
Package Licensed Method Expiration Status Details
Base site - -
NFS site - -
CIFS demo 12/7/2015 00:00:00 Demo expires on given date
iSCSI none - -
FCP none - -
SnapRestore none - -
SnapMirror none - -
FlexClone none - -
SnapVault none - -
SnapLock none - -
SnapManagerSuite none - -
SnapProtectApps none - -
V_StorageAttach none - -
SnapLock_Enterprise
none - -
Insight_Balance none - -
OCShift none - -
Cloud subscr 12/15/2015 00:00:00 Subscription expires on given date
17 entries were displayed.
