system license show-status
Display license status
This command displays the status of all Data ONTAP licenses.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-status {not-compliant|eval|partially-installed|valid|not-installed|not-applicable|not-known}]
- Current State-
If you use this parameter, the command displays information only about licenses that match the given status.
[-license <Licensable Package>]
- License-
If you use this parameter, the command displays information only about licenses that match the given license.
[-scope {site|cluster|node|pool}]
- License Scope-
If you use this parameter, the command displays information only about licenses that match the given scope.
[-detailed-status <text>,…]
- Detailed Status-
If you use this parameter, the command displays information only about licenses that match the given detailed-status.
The following example displays the license status of the cluster:
cluster1::> system license show-status Status License Scope Detailed Status --------- ------------------- --------- ---------------------- partially-installed CIFS node License missing on: Node2-Cluster1. SnapRestore node License missing on: Node2-Cluster1. valid FCP node - FabricPool cluster The system is using 1TB, and can use up to 25TB. not-installed NFS - - iSCSI - - SnapMirror - - FlexClone - - SnapVault - - SnapLock - - SnapManagerSuite - - SnapProtectApps - - V_StorageAttach - - Insight_Balance - - OCShift - - TPM - - VE - - DP_Optimized - - not-applicable Cloud - - Select - - 20 entries were displayed.
