ONTAP commands
system license show-status
Display license status
This command displays the status of all ONTAP licenses.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-status {not-compliant|eval|partially-installed|valid|not-installed|not-applicable|not-known}] - Current State
If you use this parameter, the command displays information only about licenses that match the given status.
[-license <Licensable Package>] - License
If you use this parameter, the command displays information only about licenses that match the given license.
[-scope {site|cluster|node|pool}] - License Scope
If you use this parameter, the command displays information only about licenses that match the given scope.
[-detailed-status <text>,…​] - Detailed Status
If you use this parameter, the command displays information only about licenses that match the given detailed-status.
The following example displays the license status of the cluster:
cluster1::> system license show-status
Status    License              Scope     Detailed Status
partially-installed
          CIFS                 node      License missing on: Node2-Cluster1.
          SnapRestore          node      License missing on: Node2-Cluster1.
valid
          FCP                  node      -
          FabricPool           cluster   The system is using 1TB, and can use up to 25TB.
not-installed
          NFS                  -         -
          iSCSI                -         -
          SnapMirror           -         -
          FlexClone            -         -
          SnapVault            -         -
          SnapLock             -         -
          SnapManagerSuite     -         -
          SnapProtectApps      -         -
          V_StorageAttach      -         -
          Insight_Balance      -         -
          OCShift              -         -
          TPM                  -         -
          VE                   -         -
          DP_Optimized         -         -
not-applicable
          Cloud                -         -
          Select               -         -
20 entries were displayed.
