      system bridge run-cli
Execute a CLI command on a bridge
The storage bridge run-cli command enables you to execute an ATTO bridge command.
- -name <text>- Bridge Name
This parameter specifies the name of the bridge that the command is to be executed on.
- -command <text>- CLI command to execute
This parameter specifies the command to be executed on the named bridge.
The following example executes a command on a bridge
sti8040mcc-201_siteA::> storage bridge run-cli -name ATTO_FibreBridge7500N_1 -command "Help"
 PDFs
PDFs
