The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
qos workload delete
PDF of this doc site
Creating your file...
Your file is ready
Delete workload
Deletes a workload from a cluster. When you delete a workload, the associated data object is no longer controlled by its policy group.
You can only delete user-defined workloads. You cannot delete system-defined or preset workloads.
-workload <text>
- Workload Name-
Specifies the name of the workload that you want to delete.
cluster1::> qos workload delete workload1
Deletes the "workload1" user-defined workload from the "cluster1" cluster.
