ONTAP commands
system feature-usage show-summary
Display Feature Usage Summary
Display usage summary information about features in the cluster on a per-node basis. The summary information includes counter information such as the number of weeks the feature was in use and the last date and time the feature was used. Additional information can also be displayed by using the -instance parameter.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-serial-number <Node Serial Number>] - Node Serial Number
Displays usage summary information for the specified serial number.
[-feature-name <Managed Feature>] - Feature Name
Displays usage summary information for the specified feature name.
[-weeks-in-use <integer>] - Weeks In-Use
Displays usage summary information for features matching the number of weeks in use.
[-last-used <MM/DD/YYYY HH:MM:SS>] - Date last used
Displays usage summary information for features last used on the specified date.
[-owner <text>] - Owner
Displays usage summary information for the specified owner name.
[-weeks-not-used <integer>] - Weeks Not Used
Displays usage summary information for features matching the number of weeks not in use.
[-weeks-configured <integer>] - Weeks Configured
Displays usage summary information for features matching the number of weeks that the feature was in configuration.
[-weeks-not-available <integer>] - Weeks Data Not Available
Displays usage summary information for features matching the number of weeks when usage data was not available.
The following example displays a usage summary output for a cluster of two nodes:
cluster1::> system feature-usage show-summary
Node Serial Number: 1-81-0000000000000001122334455
Owner: node1
Feature Name  Weeks In Use      Date Last Used
CIFS                         10 1/1/2013 23:27:49
NFS                          15 1/8/2013 23:48:03
Node Serial Number: 1-81-0000000000000001122334466
Owner: node2
CIFS                         10 1/1/2013 23:26:38
NFS                          20 1/8/2013 23:46:48
4 entries were displayed.
