ONTAP commands
volume snapshot modify-snaplock-expiry-time
Modify expiry time of a SnapLock Snapshot copy
The volume snapshot modify-snapshot-expiry-time extends snaplock expiry time of an existing Snapshot copy.
-vserver <vserver name> - Vserver
This specifies the Vserver that contains the volume on which the Snapshot copy is located.
-volume <volume name> - Volume
This specifies the volume where a Snapshot copy is to be located.
-snapshot <text> - Snapshot
This specifies the name of the Snapshot copy locked by SnapLock whose snaplock expiry time needs to be modified.
[-expiry-time {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm] | infinite}] - SnapLock Expiry Time
Specifies the new snaplock expiry that is applied to Snapshot copy locked by SnapLock.
If this option value is infinite , then a retention period that never expires is applied to the Snapshot copy.
The following example extends the retention period of a Snapshot copy snap1 to "03/03/2020 00:00:00" :
cluster1::> volume snapshot modify-snaplock-expiry-time -vserver vs1 -volume vol1 -snapshot snap1 -expiry-time "03/03/2020 00:00:00"
        cluster1::>
The following example extends the retention period of a Snapshot copy snap2 to infinite :
cluster1::>  volume snapshot modify-snaplock-expiry-time -vserver vs1 -volume vol1 -snapshot snap2 -expiry-time infinite
         cluster1::>
cluster1::> volume snapshot show -vserver vs1 -fields snaplock-expiry-time
         vserver volume snapshot snaplock-expiry-time
         vs1     vol1   snap1    3/3/2020 00:00:00 +05:30
         vs1     vol1   snap2    infinite
