system node coredump save-all
Save all unsaved kernel coredumps owned by a node
The system node coredump save-all saves all unsaved core dumps on a specified node. If the node has already attempted to save the core dump by the value set by the -save-attempts parameter, the command prompts you before continuing. The save-attempts parameter is set by invoking the command system node coredump config modify.
-node <nodename>- Node That Owns the Coredump-
This specifies the node on which unsaved core dumps are to be saved.
The following example saves all unsaved core dumps on a node named node0:
cluster1::> system node coredump save-all -node node0
