The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
network port broadcast-domain delete
PDF of this doc site
Creating your file...
Your file is ready
Delete a layer 2 broadcast domain
Delete a broadcast domain that contains no ports.
-ipspace <IPspace>
- IPspace Name-
The IPspace to which the broadcast domain belongs
-broadcast-domain <Broadcast Domain>
- Layer 2 Broadcast Domain-
The name of the broadcast domain to be deleted.
The following example deletes the broadcast domain "mgmt" in IPspace "Default".
cluster1::network port broadcast-domain> delete -ipspace Default -broadcast-domain mgmt
