event notification history show
Display latest events sent to destination
The event notification history show command displays a list of event messages that have been sent to a notification destination. Information displayed by the command for each event is identical to that of the event log show command. This command displays events sent to a notification destination while the event log show command displays all events that have been logged.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. -destination <text>- Destination-
Specifies the destination to which event messages have been sent to be displayed.
[-node {<nodename>|local}]- Node-
Displays a list of events for the node you specify. Use this parameter with the -seqnum parameter to display detailed information.
[-seqnum <Sequence Number>]- Sequence#-
Selects the events that match this parameter value. Use with the -node parameter to display detailed information.
[-time <MM/DD/YYYY HH:MM:SS>]- Time-
Selects the events that match this parameter value. Use the format: MM/DD/YYYY HH:MM:SS [+- HH:MM]. You can specify a time range by using the ".." operator between two time statements.
[-severity {EMERGENCY|ALERT|ERROR|NOTICE|INFORMATIONAL|DEBUG}]- Severity-
Selects the events that match this parameter value. Severity levels are as follows:
EMERGENCY - Disruption.
ALERT - Single point of failure.
ERROR - Degradation.
NOTICE - Information.
INFORMATIONAL - Information.
DEBUG - Debug information.
[-message-name <Message Name>]- Message Name-
Selects the events that match this parameter value (string). Message names are descriptive, so filtering output by message name displays messages of a specific type.
[-event <text>]- Event-
Selects the events that match this parameter value. This parameter is useful when entered with wildcards. The "event" field contains the full text of the event, including any parameters. For example, the wafl.vol.offline event displays the name of the volume that is taken offline.
The following example displays all the events which match "important-events" filter and forwarded to the "snmp-traphost" destination:
cluster1::> event filter show
Filter Rule Rule SNMP Trap
Name Posn Type Message Name Severity Type Parameters
default-trap-events
1 include * EMERGENCY, ALERT
2 include * * Standard, Built-in
3 exclude * * * *=*
important-events
2 include callhome.* ERROR * *=*
3 exclude * * * *=*
no-info-debug-events
1 include * EMERGENCY, ALERT, ERROR, NOTICE
2 exclude * * * *=*
8 entries were displayed.
cluster1::> event notification destination show
Name Type Destination
snmp-traphost snmp 192.168.10.40 (from "system snmp traphost")
cluster1::> event notification show
ID Filter Name Destinations
1 important-events snmp-traphost
cluster1::>event notification history show -destination snmp-traphost
Time Node Severity Event
5/14/2015 03:02:09 node1 EMERGENCY callhome.clam.node.ooq: Call home for NODE(S) OUT OF CLUSTER QUORUM.
5/13/2015 12:05:45 node1 ALERT od.rdb.mbox.read.error: message="RDB-HA readPSlot: Failed to read blob_type 19, (pslot 16), instance 1: 1 (1)."
2 entries were displayed.
