lun import stop
PDF of this doc site
Creating your file...
Your file is ready
Stop the import for the specified LUN
This command stops the data import into a specified LUN.
After you stop the data import and if you start the import again using lun import start command, then the import restarts from the beginning.
-vserver <Vserver Name>
- Vserver Name (privilege: advanced)-
Specifies the Vserver that contains the LUN you want to stop importing data to.
-path <path>
- LUN Path (privilege: advanced)-
Specifies the path of the LUN that you want to stop the data import to.
cluster1::> lun import stop -vserver vs1 -path /vol/vol2/lun2
Stops data import to lun2 at the path /vol/vol2/lun2
