      lun import stop
Stop the import for the specified LUN
This command stops the data import into a specified LUN.
After you stop the data import and if you start the import again using lun import start command, then the import restarts from the beginning.
- -vserver <Vserver Name>- Vserver Name (privilege: advanced)
Specifies the Vserver that contains the LUN you want to stop importing data to.
- -path <path>- LUN Path (privilege: advanced)
Specifies the path of the LUN that you want to stop the data import to.
cluster1::> lun import stop -vserver vs1 -path /vol/vol2/lun2
Stops data import to lun2 at the path /vol/vol2/lun2
 PDFs
PDFs
