storage pool show-disks
PDF of this doc site
Creating your file...
Display disks in storage pools
The storage pool show-disks
command displays information about disks in storage pools in the cluster. The command output depends on the parameter or parameters specified with the command. If no parameters are specified, the command displays information about all disks in all storage pools in the cluster.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-storage-pool <storage pool name>]
- Name of Storage Pool-
Selects the storage pools that match this parameter value.
[-disk <disk path name>]
- Name of the disk-
Selects the storage pools with the disks that match this parameter value.
[-disk-type {ATA | BSAS | FCAL | FSAS | LUN | MSATA | SAS | SSD | VMDISK | SSD-NVM | SSD-CAP | SSD-ZNS | VMLUN | VMLUN-SSD}]
- Disk Type-
Selects the storage pools with the disks that match this parameter value. Only the
SSD
type is supported for this version of Data ONTAP. [-usable-size {<integer>[KB|MB|GB|TB|PB]}]
- Disk Usable Size-
In this command,
usable-size
refers to the sum of the capacities of all of the partitions on the disk. [-total-size {<integer>[KB|MB|GB|TB|PB]}]
- Total Size-
[-node-list <nodename>,…]
- List of Nodes-
Selects the storage pools with the disks that are visible to all of the specified nodes.
Show information about SSDs in a storage pool called SP2
cluster1::> storage pool show-disks -storage-pool SP2 Storage Pool Name: SP2 Storage Disk Type Usable Size Total Size -------- ------- ----------- ----------- 1.0.16 SSD 745.0GB 745.2GB 1.0.18 SSD 745.0GB 745.2GB 1.0.20 SSD 745.0GB 745.2GB 1.0.22 SSD 745.0GB 745.2GB
