ONTAP commands
storage pool show-disks
Display disks in storage pools
The storage pool show-disks command displays information about disks in storage pools in the cluster. The command output depends on the parameter or parameters specified with the command. If no parameters are specified, the command displays information about all disks in all storage pools in the cluster.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-storage-pool <storage pool name>] - Name of Storage Pool
Selects the storage pools that match this parameter value.
[-disk <disk path name>] - Name of the disk
Selects the storage pools with the disks that match this parameter value.
[-disk-type {ATA | BSAS | FCAL | FSAS | LUN | MSATA | SAS | SSD | VMDISK | SSD-NVM | SSD-CAP | SSD-ZNS | VMLUN | VMLUN-SSD}] - Disk Type
Selects the storage pools with the disks that match this parameter value. Only the SSD type is supported for this version of ONTAP.
[-usable-size {<integer>[KB|MB|GB|TB|PB]}] - Disk Usable Size
In this command, usable-size refers to the sum of the capacities of all of the partitions on the disk.
[-total-size {<integer>[KB|MB|GB|TB|PB]}] - Total Size
[-node-list <nodename>,…​] - List of Nodes
Selects the storage pools with the disks that are visible to all of the specified nodes.
Show information about SSDs in a storage pool called SP2 .
cluster1::> storage pool show-disks -storage-pool SP2
Storage Pool Name: SP2
Storage
    Disk     Type    Usable Size  Total Size
    1.0.16   SSD         745.0GB     745.2GB
    1.0.18   SSD         745.0GB     745.2GB
    1.0.20   SSD         745.0GB     745.2GB
    1.0.22   SSD         745.0GB     745.2GB
