ONTAP commands
qos settings cache show
Display list of cache policies
The ` qos settings cache show` shows the current caching-policies, class to which they belong, the number of workloads associated with each of the policies, and whether or not they are set to default. The following external-cache policies are available:
  • none - Does not cache any user data or metadata blocks.
  • auto - Read caches all metadata and randomly read user data blocks, and write caches all randomly overwritten user data blocks.
{ [-fields <fieldname>,…​]
The input to this parameter is one of the following: {cache-setting|class|default|num-workloads}. If you use this parameter, the command displays information related to the specified input field.
| [-instance ] }
If you use this parameter, the command displays information about the caching-policies in a list format.
[-cache-setting <text>] - Cache Policy Name
The input to this parameter is any one of the above listed caching-policies. If you use this parameter, the command displays information corresponding to the specified caching-policy.
[-class <QoS Configuration Class>] - Cache Policy Class
The input to this parameter is one of the following: {undefined|preset|user-defined|system-defined|autovolume}. If you use this parameter, the command displays information corresponding to the specified policy-group class.
[-default {true|false}] - Is Default?
The input to this parameter is true and false. If you use this parameter, the command displays information corresponding to entries that have the specified default value.
[-num-workloads <integer>] - Number Of Workloads With This Policy
The input to this parameter is an integer. If you use this parameter, the command displays information about policy-groups matching the specified number of workloads.
cluster1::> qos settings cache show
Policy Name  Class        Num Workloads        Default
all          preset       0                    false
all-random_write
             preset       0                    false
all_read     preset       0                    false
all_read-random_write
             preset       0                    false
all_read_random_write
             preset       0                    false
all_read_random_write-random_write
             preset       0                    false
auto         preset       2                    false
meta         preset       0                    false
meta-random_write
             preset       0                    false
none         preset       0                    false
noread-random_write
             preset       0                    false
random_read  preset       25                   false
random_read_write
             preset       0                    false
random_read_write-random_write
             preset       28                   true
14 entries were displayed.
Shows QoS settings for the caching policies.
