qos settings cache show
Display list of cache policies
The ` qos settings cache show` shows the current caching-policies, class to which they belong, the number of workloads associated with each of the policies, and whether or not they are set to default. The following external-cache policies are available:
none - Does not cache any user data or metadata blocks.
auto - Read caches all metadata and randomly read user data blocks, and write caches all randomly overwritten user data blocks.
all - Read caches all data blocks read and written. It does not do any write caching.
all-random_write - Read caches all data blocks read and written. It also write caches randomly overwritten user data blocks.
all_read - Read caches all metadata, randomly read, and sequentially read user data blocks.
all_read-random_write - Read caches all metadata, randomly read, and sequentially read user data blocks. It also write caches randomly overwritten user data blocks.
all_read_random_write - Read caches all metadata, randomly read, sequentially read and randomly written user data.
all_read_random_write-random_write - Read caches all metadata, randomly read, sequentially read, and randomly written user data blocks. It also write caches randomly overwritten user data blocks.
meta - Read caches only metadata blocks.
meta-random_write - Read caches all metadata and write caches randomly overwritten user data blocks.
noread-random_write - Write caches all randomly overwritten user data blocks. It does not do any read caching.
random_read - Read caches all metadata and randomly read user data blocks.
random_read_write - Read caches all metadata, randomly read and randomly written user data blocks.
random_read_write-random_write - Read caches all metadata, randomly read, and randomly written user data blocks. It also write caches randomly overwritten user data blocks.
Note that in a caching-policy name, a hyphen (-) separates read and write caching policies. |
[-fields <fieldname>,…]
The input to this parameter is one of the following: {cache-setting|class|default|num-workloads}. If you use this parameter, the command displays information related to the specified input field.
[-instance ]
If you use this parameter, the command displays information about the caching-policies in a list format.
[-cache-setting <text>]
- Cache Policy Name-
The input to this parameter is any one of the above listed caching-policies. If you use this parameter, the command displays information corresponding to the specified caching-policy.
[-class <QoS Configuration Class>]
- Cache Policy Class-
The input to this parameter is one of the following: {undefined|preset|user-defined|system-defined|autovolume}. If you use this parameter, the command displays information corresponding to the specified policy-group class.
[-default {true|false}]
- Is Default?-
The input to this parameter is true and false. If you use this parameter, the command displays information corresponding to entries that have the specified default value.
[-num-workloads <integer>]
- Number Of Workloads With This Policy-
The input to this parameter is an integer. If you use this parameter, the command displays information about policy-groups matching the specified number of workloads.
cluster1::> qos settings cache show Policy Name Class Num Workloads Default ------------ ------------ ------------- ------- all preset 0 false all-random_write preset 0 false all_read preset 0 false all_read-random_write preset 0 false all_read_random_write preset 0 false all_read_random_write-random_write preset 0 false auto preset 2 false meta preset 0 false meta-random_write preset 0 false none preset 0 false noread-random_write preset 0 false random_read preset 25 false random_read_write preset 0 false random_read_write-random_write preset 28 true 14 entries were displayed.
Shows QoS settings for the caching policies.
