The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver fcp delete
PDF of this doc site
Creating your file...
Your file is ready
Delete FCP service configuration
Deletes an FCP service of a Vserver. Before you can delete an FCP service, the administration status must be down
. Use the vserver fcp modify command to change the administration status.
-vserver <Vserver Name>
- Vserver Name-
Specifies the Vserver for the FCP service.
cluster1::> vserver fcp delete -vserver vs_1
Deletes the FCP service on Vserver vs_1
