system services firewall policy show
(DEPRECATED)-Show firewall policies
This command is deprecated and may be removed in a future ONTAP release. Use network interface service-policy show instead. |
The system services firewall policy show command displays information about firewall policies.
Some firewall policies contain a single entry for the "none" firewall service. You can consider these policies to be empty. When used by a logical network interface (LIF), an empty firewall policy will block all services managed using firewall policies. |
[-fields <fieldname>,…] -
If you specify the
-fields <fieldname>,…parameter, the command displays only the fields that you specify. - |
[-instance ]} -
Use this parameter to display all the fields for the specified policies.
 [-vserver <vserver>]- Vserver Name-
Use this parameter to display information only about the Vserver you specify.
 [-policy <textpolicy_name>]- Policy-
Use this parameter to display information about the policy you specify.
 [-service <service>]- Service-
Use this parameter to display information about the services you specify.
 [-allow-list <IP Address/Mask>,…]- Allowed IPs-
Use this parameter to display information about the firewall policies that match the list of allowed IP addresses and netmasks you specify. The correct format for this parameter is address/netmask, similar to "192.0.2.128/25". Multiple address/netmask pairs should be separated with commas.
 [-ipspace <text>]- IPspace-
Use this parameter to display information only about the IPspace you specify.
The following example displays information about all firewall policies:
cluster1::> system services firewall policy show
Vserver Policy       Service    Allowed
cluster1
        data
                     dns        0.0.0.0/0, ::/0
                     ndmp       0.0.0.0/0, ::/0
                     ndmps      0.0.0.0/0, ::/0
cluster1
        intercluster
cluster1
        mgmt
                     dns        0.0.0.0/0, ::/0
                     http       0.0.0.0/0, ::/0
                     ntp        0.0.0.0/0, ::/0
                     snmp       0.0.0.0/0, ::/0
cluster1
        mgmt-nfs
                     dns        0.0.0.0/0, ::/0
                     ntp        0.0.0.0/0, ::/0
17 entries were displayed.
cluster1::>
