volume quota policy rename
Rename a quota policy
This command renames a quota policy. You must enter the following information to rename a quota policy:
  • Vserver name
  • Policy name
  • New policy name
-vserver <vserver name> - Vserver
This parameter specifies the Vserver containing the quota policy you want to rename.
-policy-name <text> - Policy Name
This parameter specifies the name of the quota policy you are renaming.
-new-policy-name <text> - New Policy Name
This parameter specifies the new name of the quota policy. The new name cannot be more than 32 characters long.
The following example renames a quota policy named quota_policy_0 on Vserver vs0. The policy's new name is quota_policy_1.
cluster1::> volume quota policy rename -vserver vs0 -policy-name quota_policy_0 -new-policy-name quota_policy_1
