ONTAP commands
snapmirror mediator primary-bias history show
Show Primary Bias History
The snapmirror mediator primary-bias history show command shows the history of Primary bias events.
The setting/clearing of the Primary Bias states (including the intermediate state) will be logged as event history per CG endpoint in the "snapmirror mediator primary bias history" command. The "mediator-engaged/disengaged-for-failover" actions will represent the setting/clearing of the intermediate state preventing Failover on slave endpoints of a CG. The "primary-bias-activated/not-activated" will represent the state that allows master endpoints to assume the I/O serving authority.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-cg-path {<[vserver:][volume]>|<[[cluster:]//vserver/]volume>|<hostip:/lun/name>|<hostip:/share/share-name>|<[vserver:]/cg/[app-cgname]>}] - Cg Path
CG path.
[-start-time <MM/DD/YYYY HH:MM:SS>] - TBA Task Start Time
Time of event
[-action {Primary bias activated. Mediator Disengaged|Primary bias not-activated. Mediator engaged|Mediator disengaged for failover|Mediator engaged for failover}] - Event
Primary bias event.
The following example shows the history output
C1_sti7-vsim-ucs569m_cluster::*> snapmirror mediator primary-bias history show -cg-path vs0:/cg/scg
    CG Path        Time                Action
    vs0:/cg/scg    7/25/2022 10:33:28
    vs0:/cg/scg    7/25/2022 22:42:33
            primary-bias-not-activated
    2 entries were displayed.
