system bridge config-dump collect
- PDF of this doc site
Creating your file...
Your file is ready
Retrieve and save bridge dumpconfiguration
The system bridge config-dump collect
command retrieves a dumpconfiguration file from a system bridge.
-bridge <text>
- Bridge Name (privilege: advanced)-
Use this parameter to retrieve a dumpconfiguration file from the specified bridge.
The following example retrieves a dumpconfiguration file from bridge ATTO_FibreBridge7500N_1:
cluster1::*> system bridge config-dump collect -bridge ATTO_FibreBridge7500N_1 [Job 883] Job is queued: Collect the dumpconfiguration file from bridge "ATTO_FibreBridge7500N_1". cluster1::*>
