      system bridge config-dump collect
Retrieve and save bridge dumpconfiguration
The system bridge config-dump collect command retrieves a dumpconfiguration file from a system bridge.
- -bridge <text>- Bridge Name (privilege: advanced)
Use this parameter to retrieve a dumpconfiguration file from the specified bridge.
The following example retrieves a dumpconfiguration file from bridge ATTO_FibreBridge7500N_1:
cluster1::*> system bridge config-dump collect -bridge ATTO_FibreBridge7500N_1 [Job 883] Job is queued: Collect the dumpconfiguration file from bridge "ATTO_FibreBridge7500N_1". cluster1::*>
 PDFs
PDFs
