vserver cifs users-and-groups privilege reset-privilege
Reset local privileges for a user or group
The vserver cifs users-and-groups privilege reset-privilege command resets privileges of a local or Active Directory user or group.
-vserver <vserver name>- Vserver-
This specifies the name of the Vserver.
-user-or-group-name <CIFS name>- User or Group Name-
This specifies the name of the local or Active Directory user or group.
The following example resets the privileges for the local user "CIFS_SERVER\u1". This operation removes the privilege entry, if any, associated with the local user "CIFS_SERVER\u1".
cluster1::> vserver cifs users-and-groups privilege show
Vserver User or Group Name Privileges
vs1 CIFS_SERVER\u1 SeTakeOwnershipPrivilege
SeRestorePrivilege
cluster1::> vserver cifs users-and-groups privilege reset-privilege -vserver vs1 -user-or-group-name CIFS_SERVER\u1
This table is currently empty.
+ + The following example resets the privileges for the group "BUILTIN\Administrators", effectively removing the privilege entry.
vs1 BUILTIN\Administrators SeRestorePrivilege
SeSecurityPrivilege
cluster1::> vserver cifs users-and-groups privilege reset-privilege -vserver vs1 -user-or-group-name BUILTIN\Administrators
