Command reference
vserver cifs users-and-groups privilege reset-privilege
Reset local privileges for a user or group
The vserver cifs users-and-groups privilege reset-privilege command resets privileges of a local or Active Directory user or group.
-vserver <vserver name> - Vserver
This specifies the name of the Vserver.
-user-or-group-name <CIFS name> - User or Group Name
This specifies the name of the local or Active Directory user or group.
The following example resets the privileges for the local user "CIFS_SERVER\u1". This operation removes the privilege entry, if any, associated with the local user "CIFS_SERVER\u1".
cluster1::> vserver cifs users-and-groups privilege show
Vserver        User or Group Name           Privileges
vs1            CIFS_SERVER\u1               SeTakeOwnershipPrivilege
                                            SeRestorePrivilege
cluster1::> vserver cifs users-and-groups privilege reset-privilege -vserver vs1 -user-or-group-name CIFS_SERVER\u1
This table is currently empty.
The following example resets the privileges for the group "BUILTIN\Administrators", effectively removing the privilege entry.
vs1            BUILTIN\Administrators       SeRestorePrivilege
                                            SeSecurityPrivilege
cluster1::> vserver cifs users-and-groups privilege reset-privilege -vserver vs1 -user-or-group-name BUILTIN\Administrators
