The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
volume recovery-queue purge-all
PDF of this doc site
Creating your file...
Your file is ready
Purge all volumes from the recovery queue belonging to a Vserver
The volume recovery-queue purge-all
command purges all volumes from the recovery queue belonging to a Vserver.
-vserver <vserver name>
- Vserver name (privilege: advanced)-
This specifies the Vserver whose volumes in the recovery queue need to be purged.
The following example purges all volumes on a Vserver named vs1 from the recovery queue.
cluster1::*> volume recovery-queue purge-all -vserver vs1
