ONTAP commands
volume recovery-queue purge-all
Purge all volumes from the recovery queue belonging to a Vserver
The volume recovery-queue purge-all command purges all volumes from the recovery queue belonging to a Vserver.
-vserver <vserver name> - Vserver name (privilege: advanced)
This specifies the Vserver whose volumes in the recovery queue need to be purged.
The following example purges all volumes on a Vserver named vs1 from the recovery queue.
cluster1::*> volume recovery-queue purge-all -vserver vs1
