      security certificate config modify
Modify the certificate management configurations
This command modifies the certificate management configuration information for the cluster.
- [-min-security-strength <bits of security strength>]- Minimum Security Strength
Use this parameter to modify the allowed minimum security strength for certificates. The security bits mapping to RSA and ECDSA key length are as follows:
            Security Bits   Asymmetric Key Length   Elliptic Curve Key Length
            112	            2048	                224
            128	            3072	                256
            192	            4096	                384
FIPS supported values are restricted to 112 and 128.
NOTE: This does not affect root CA certificates.
- [-expiration-warn-threshold <integer>]- Minimum Days to EMS for Expiring Certificates
Use this parameter to modify the number of days prior to certificate expiration the system sends a warning EMS event.
The following example modifies the minimum security strength allowed for certificates.
cluster-1::> security certificate config modify -min-security-strength 192
 PDFs
PDFs
