ONTAP commands
security certificate config modify
Modify the certificate management configurations
This command modifies the certificate management configuration information for the cluster.
[-min-security-strength <bits of security strength>] - Minimum Security Strength
Use this parameter to modify the allowed minimum security strength for certificates. The security bits mapping to RSA and ECDSA key length are as follows:
            Security Bits   Asymmetric Key Length   Elliptic Curve Key Length
            112	            2048	                224
            128	            3072	                256
            192	            4096	                384
FIPS supported values are restricted to 112 and 128.
Note This does not affect root CA certificates.
[-expiration-warn-threshold <integer>] - Minimum Days to EMS for Expiring Certificates
Use this parameter to modify the number of days prior to certificate expiration the system sends a warning EMS event.
The following example modifies the minimum security strength allowed for certificates.
cluster-1::> security certificate config modify -min-security-strength 192
