ONTAP commands
volume file async-delete client disable
Disable async delete of a directory from the client
The volume file async-delete client disable command disables async delete of a directory on the volume, from client applications.
-vserver <vserver name> - Vserver Name (privilege: advanced)
This specifies the Vserver on which the volume resides.
-volume <volume name> - Volume Name (privilege: advanced)
This specifies the name of the volume.
The following example disables async directory delete from the client in volume "vol1" hosted in Vserver "vs1".
cluster1::*> volume file async-delete client disable -vserver vs1 -volume vol1
