system services firewall modify
Modify firewall status
The system services firewall modify
command modifies a node's firewall configuration.
-node {<nodename>|local}
- Node-
Use this parameter to specify the node on which to modify firewall configuration.
[-enabled {true|false}]
- Service Enabled-
Use this parameter to specify whether firewall protection is enabled ("
true
") or disabled ("false
") for the node's network ports. The default setting istrue
The following example enables firewall protection for a node named node1:
cluster1::> system services firewall modify -node node1 -enabled true
