ONTAP commands
security oauth2 modify
Modify global OAuth 2.0 configuration
The security oauth2 modify command enables or disables the OAuth 2.0 feature for token-based authentication.
[-enabled {true|false}] - OAuth 2.0 Enabled
Use this parameter to enable or disable the OAuth 2.0 feature for the cluster.
The following example enables the OAuth 2.0 feature for the cluster:
cluster1::> security oauth2 modify -enabled true
