vserver vscan on-demand-task report show
Display On-Demand reports
The vserver vscan on-demand-task report show command displays information about the On-Demand reports belonging to the Vserver. A new report record is generated at the end of an On-Demand task run. If you do not specify any parameters, the command displays the following information about all On-Demand tasks:
Vserver name
Task name
Report file path
Number of clean files
Number of infected files
You can specify the -fields parameter to specify which fields of information to display about On-Demand report. In addition to the fields above, you can display the following fields:
Job ID
Job duration
Number of attempted scans
Number of files skipped from scanning
Number of already scanned files
Number of successful scans
Number of failed scans
Number of timed-out scans
Job start time
Job end time
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
If you specify this parameter, the command displays information only about the On-Demand reports for the specified Vserver.
[-task-name <text>]- Task Name-
If you specify this parameter, the command displays information only about the On-Demand reports for the specified task.
[-report-file <text>]- Report File Path-
If you specify this parameter, the command displays information only about the On-Demand reports that have the specified report file-path.
[-job-id <integer>]- Job ID-
If you specify this parameter, the command displays information only about the On-Demand reports that have the specified job ID.
[-job-duration <[<integer>d][<integer>h][<integer>m][<integer>s]>]- Job Duration-
If you specify this parameter, the command displays information only about the On-Demand reports that have the specified value.
[-attempted-scans <integer>]- Number of Attempted Scans-
[-skipped-scans <integer>]- Number of Files Skipped from Scanning-
[-already-scanned-files <integer>]- Number of Already Scanned Files-
[-successful-scans <integer>]- Number of Successful Scans-
[-failed-scans <integer>]- Number of Failed Scans-
[-timedout-scans <integer>]- Number of Timedout Scans-
[-files-cleaned <integer>]- Number of Clean Files-
[-files-infected <integer>]- Number of Infected Files-
[-internal-error <integer>]- Number of Internal Error (privilege: advanced)-
[-scan-retries <integer>]- Number of Scan Retries (privilege: advanced)-
[-job-start-time <MM/DD/YYYY HH:MM:SS>]- Job Start Time-
[-job-end-time <MM/DD/YYYY HH:MM:SS>]- Job End Time-
The following example displays information about all On-Demand reports:
cluster1::> vscan on-demand-task report show
Files Files
Vserver Task Name Report File Path Cleaned Infected
vs1 t1 /rep/avod_146_20150902_161439.log 6240 5
vs1 t1 /rep/avod_149_20150903_160313.log 115 0
2 entries were displayed.
The following example displays detailed information about an On-Demand task:
cluster1::> vscan on-demand-task report show -vserver vs1 -task-name t1
-report-file /rep/avod_146_20150902_161439.log
Vserver: vs1
Task Name: t1
Report File Path: /rep/avod_146_20150902_161439.log
Job ID: 146
Job Duration: 76s
Number of Attempted Scans: 6245
Number of Files Skipped from Scanning: 1286
Number of Already Scanned Files: 987
Number of Successful Scans: 6245
Number of Failed Scans: 0
Number of Timedout Scans: 0
Number of Clean Files: 6240
Number of Infected Files: 5
Job Start Time: 9/2/2015 16:14:39
Job End Time: 9/2/2015 16:15:55
