system service-processor show
Display the Service Processor information
The system service-processor show command displays information about the Service Processor of each node in a cluster. You can limit output to specific types of information and specific nodes in the cluster, or filter output by specific field values.
In case a node is offline or its Service Processor management daemon is down, the command displays the last known IP address of its Service Processor. Only the IP address is displayed in such cases.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Selects information for the Service Processor of the specified node.
[-type {SP|NONE|BMC}]- Type of Device-
Selects information for the Service Processors of the specified type.
[-status {online|offline|sp-daemon-offline|node-offline|degraded|rebooting|unknown|updating}]- Status-
Selects information for the Service Processors whose status matches the specified value.
[-ip-configured {true|false}]- Is Network Configured-
Selects information for the Service Processors whose network is configured (
true) or not configured (false). [-address <IP Address>,…]- Public IP Address-
Selects information for the Service Processors that use the specified IP address or addresses.
[-mac <MAC Address>]- MAC Address-
Selects information for the Service Processors that use the specified MAC address.
[-fw-version <text>]- Firmware Version-
Selects information for the Service Processors that are running the specified firmware version.
[-part-num <text>]- Part Number-
Selects information for the Service Processors that have the specified part number.
[-serial-num <text>]- Serial Number-
Selects information for the Service Processors that have the specified serial number.
[-dev-rev <text>]- Device Revision-
Selects information for the Service Processors that have the specified device revision.
[-autoupdate-enabled {true|false}]- Is Firmware Autoupdate Enabled-
Selects information for the Service Processors that have the specified status for firmware automatic update.
The following example displays basic information for the Service Processors of all the nodes.
cluster1::> system service-processor show
IP Firmware
Node Type Status Configured Version IP Address
node1 SP online true 2.2X5 192.168.1.201
node2 SP online true 2.2X5 192.168.1.202
2 entries were displayed.
cluster1::>
The following example displays all available information for the Service Processors of all the nodes.
cluster1::> system service-processor show -instance
Node: node1
Type of Device: SP
Status: online
Is Network Configured: true
Public IP Address: 192.168.1.201
MAC Address: ab:cd:ef:fe:ed:01
Firmware Version: 2.2X5
Part Number: Not Applicable
Serial Number: Not Applicable
Device Revision: Not Applicable
Is Firmware Autoupdate Enabled: true
Node: node2
Type of Device: SP
Status: online
Public IP Address: 192.168.1.202
MAC Address: ab:cd:ef:fe:ed:02
cluster1::>
The following example displays only the type, status and firmware version for the Service Processors of all the nodes.
cluster1::> system service-processor show -fields type,status,fw-version node type status fw-version ------------- ---- ------ ---------- node1 SP online 2.2X5 node2 SP online 2.2X5 2 entries were displayed. cluster1::>
