system service-processor show
Display the Service Processor information
The system service-processor show
command displays information about the Service Processor of each node in a cluster. You can limit output to specific types of information and specific nodes in the cluster, or filter output by specific field values.
In case a node is offline or its Service Processor management daemon is down, the command displays the last known IP address of its Service Processor. Only the IP address is displayed in such cases.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Selects information for the Service Processor of the specified node.
[-type {SP|NONE|BMC}]
- Type of Device-
Selects information for the Service Processors of the specified type.
[-status {online|offline|sp-daemon-offline|node-offline|degraded|rebooting|unknown|updating}]
- Status-
Selects information for the Service Processors whose status matches the specified value.
[-ip-configured {true|false}]
- Is Network Configured-
Selects information for the Service Processors whose network is configured (
true
) or not configured (false
). [-address <IP Address>,…]
- Public IP Address-
Selects information for the Service Processors that use the specified IP address or addresses.
[-mac <MAC Address>]
- MAC Address-
Selects information for the Service Processors that use the specified MAC address.
[-fw-version <text>]
- Firmware Version-
Selects information for the Service Processors that are running the specified firmware version.
[-part-num <text>]
- Part Number-
Selects information for the Service Processors that have the specified part number.
[-serial-num <text>]
- Serial Number-
Selects information for the Service Processors that have the specified serial number.
[-dev-rev <text>]
- Device Revision-
Selects information for the Service Processors that have the specified device revision.
[-autoupdate-enabled {true|false}]
- Is Firmware Autoupdate Enabled-
Selects information for the Service Processors that have the specified status for firmware automatic update.
The following example displays basic information for the Service Processors of all the nodes.
cluster1::> system service-processor show IP Firmware Node Type Status Configured Version IP Address ------------- ---- ----------- ------------ --------- ------------------------- node1 SP online true 2.2X5 192.168.1.201 node2 SP online true 2.2X5 192.168.1.202 2 entries were displayed. cluster1::>
The following example displays all available information for the Service Processors of all the nodes.
cluster1::> system service-processor show -instance Node: node1 Type of Device: SP Status: online Is Network Configured: true Public IP Address: 192.168.1.201 MAC Address: ab:cd:ef:fe:ed:01 Firmware Version: 2.2X5 Part Number: Not Applicable Serial Number: Not Applicable Device Revision: Not Applicable Is Firmware Autoupdate Enabled: true Node: node2 Type of Device: SP Status: online Is Network Configured: true Public IP Address: 192.168.1.202 MAC Address: ab:cd:ef:fe:ed:02 Firmware Version: 2.2X5 Part Number: Not Applicable Serial Number: Not Applicable Device Revision: Not Applicable Is Firmware Autoupdate Enabled: true 2 entries were displayed. cluster1::>
The following example displays only the type, status and firmware version for the Service Processors of all the nodes.
cluster1::> system service-processor show -fields type,status,fw-version node type status fw-version ------------- ---- ------ ---------- node1 SP online 2.2X5 node2 SP online 2.2X5 2 entries were displayed. cluster1::>
