ONTAP commands
vserver peer transition show
Display transition peer relationships.
The vserver peer transition show command displays the following information about transition peer transition relationships:
  • Local Vserver name
  • Source 7-Mode system
  • Multi-path address
  • Local LIFs
{ [-fields <fieldname>,…​]
| [-instance ] }
[-local-vserver <vserver name>] - Local Vserver name
If this parameter is specified, the command displays transition peer information about the specified local Vserver.
[-src-filer-name <text>] - Source 7-Mode system
If this parameter is specified, the command displays transition peer information about the specified source 7-Mode system.
[-multi-path-address <text>] - Additional address for source 7-Mode system
If this parameter is specified, the command displays information about the specified multipath-address.
[-local-lifs <lif-name>,…​] - List of Local LIFs
If this parameter is specified, the command displays information about the specified local LIFs.
cluster1::> vserver peer transition show
Vserver  Source Filer  Multi Path Address    Local LIFs
vs1.example.com                              lif1, lif2
          src1.example.com
                        src1-e0b.example.com
